I cut a few extra of these out and thought some of you might like them. This will allow you to securely mount 50 cal ammo cans without drilling holes in the can itself. Your can still stays water tight and can quickly be removed from the mount. There is also a hole that a padlock with a 1/4" shank will pass through so you can make the cans less likely to walk off.
There are a few rough spots where my plasma table had some issues. It is only cosmetic and does not effect the use of them.
I will take $15 each for the mounts because of the rough spots. If I cut anymore later they will be more expensive. Ammo can or lock not included.
Untitled by dresselhausfc, on Flickr
