I see an IMG tag but no picture. I don't know the resistor value but might be able to figure it out if I had good pictures of the circuit and/or a Ford part # that could lead to some online.
Hmm, okay I looked around and now understand the significance of that "510" in your title. That means it's a 51 ohm resistor. The wattage will be based on the package size so you should measure the length and width of those remaining with a caliper (or best guess with a ruler) then you can take that and input it at an electronics supplier site like
www.digikey.com
For example on the following link, if you measured the resistor package size to be 6.4mm long by 3.2mm wide, that would be a "Package / Case" size of 6432 metric. If none of the sizes offered are as big as your original then you'll need to backtrack and pick some other resistor values very close to 51ohms, pick a few of them THEN pick the right case size, THEN pick the value closest to 51 ohms. I hope I'm making this part of the part selection clear. If you provide the dimensions then I can just look that up for you.
Chip Resistor - Surface Mount | DigiKey
