In my 2003 Explorer Sportrac this last winter, my tranmission had a very experence with my 16 year old son and 4 foot snow drift; I was hoping for the best and rebuilt a donor valve body with no luck (first low hear went out then 2nd went out)
So while I have always done my own auto repair after getting costs togather to have the transmission rebuilt/repaired I decided on used transmission that comes with a 1 year warrenty and has 48k miles on it.
I have got the old transmission out and I'm trying to get the replacement in but I can't get the splines lined up, while I have done some major repair projects before this is the second time I have drop and re-installed a transmission at least on something this new (old '77 chevys have enough room underneath to do just about anything you want to under them!)
ANYHOW as I pulled the old tranny out, I didn't unbolt the flex plate from the TC and I later unbolted it and remove the TC after the transmission was out which I am replacing with the one that came with the used tranny; after doing some searching I believe I shouldn't have bolted the TC up until after the tranny is bolted in; is this correct? I have been fighting this all day with no success until I came across a few posts here describing the proper manner to remove the transmission which involves unbolting the TC prior to sliding the transmission out so I am assumeing that I am not getting the spline shaft lined up and seated right since as it stands I'm trying to seat the transmission with the TC completed bolted in....
Right?? Feel free to offer your advice, I'm getting baptised in fire in with this and U'm new to the transmission scene of this nature!
Thanks!
Thanks!
