Have to reinstalled the rebuilt valve body? If so, are you still having the same shifting issues? Did you replace, or clean any solenoids while rebuilding the valve body? As far as posting pictures, they are only links. Look at the link in the photo gallery, and right click where it says copy. After doing this, right click where it says paste.
Well I think you found your problem. I will say that the diagram and text are a bit wrong ,I think. It's a picture and text for a 4R44E which has only 4 gears as opposed to a 5R55E which of course has 5 gears. If you look at the text, there is no 4-5 shift valve. I'll have to have a look later to confirm.
Anyway that sticky valve you found is for the 3-4 shift which controls the direct clutch. Did you ever lose reverse???
The servo piston is chipped in the first set of pictures. They sell them separately at WWW.TransmissionPartsUSA.Com. It's a good idea to save the pictures in the photo gallery, so if somebody (or yourself) ever want to do a search for a picture of a damaged servo to put into one of their threads, it would be easier to find. They would have to link the picture into their thread by doing this:.![]()
