calisoundmix
- July 20, 2007
- san jose, ca
- '98 XLT SOHC
So, I've been upgrading my ex over the past few weeks, and first off I couldn't have done it without the wealth of info on this site, and will be upgrading to elite soon, but on to my problem at hand...
background info: 1998 Ford Explorer SOHC, 2WD, 140,000 mi.
I just finished the tranny filter change (following this guide) and loaded it up with Mobil1 Fully Synthetic ATF, other than the old fluid shower ran into very little problems. some of the old ATF leaked onto the catalytic converter, but most of it was mopped up, some of it burned off upon taking a test drive after. there was also a few times when i was flushing the fluid that the flow slowed down (was at full flow most of the time), sometimes almost stopping.
so after taking it out for a test run i notice that there are some shifting issues in low gears, for example it will only shift into first gear half the time, the other half i have to rev it up to ~2500 RPM and it then drops into gear and surges forward, once it catches all is fine but if i come to a complete stop it has a 50% chance of failing to catch and revs up again. it will sometimes also have trouble shifting from first to second, same symptoms but revs closer to 3000 RPM before dropping into gear. Once it reaches third gear I have no more shifting issues and it performs like a champ, smoother shifts than before the fluid change. Before the filter/fluid change i had no shifting problems other than O/D taking a while to kick in sometimes.
based on my reading around here, a likely culprit is the EPC solenoid, I just wanted to check to see if there are other possibilities. i was looking at doing
so my questions are...
1). does this sound like a failing EPC?
2). Could this be another issue(s) based on the symptoms?
3). will the old ATF spilled on the catalytic converter harm it in any way?
sorry for the long post but unfortunatly i get to work a long day tomorrow (some labor day huh?) taking down a stage for a reggae festival in monterey, so i won't be able to check this until monday night. thanks for all the help.
