gettin nowhere
- September 14, 2008
- 99'EddieBauer4SOHC 5R55E
Hello to everyone! I was backing out of my driveway today and after about 15 feet this gosh awful grinding sound came from the transmission. It would only do it in reverse. When in all other gears it was fine. Bur every time it was put in reverse it would sound kind of like a gear or gears grinding against a metal drum or something. I recently about (maybe 2-3000 miles) changed the fluid and filter with an additive (without any stop leak). Had no problems until this happened. I checked the shifter on the side of the trans. and it seemed apparent that the shifter dtents were actually in there respective places. But, still nothing. The Explorer has just over 200K on it so I'm not complaining. I'm just looking for ideas on what the problem may be ie. pump, T. converter or what. By the way the fluid is clean and doesn't smell burnt and is at the correct level. Thanks for any advice or insight.
4.0 SOHC
4.10 gear in rearend
5R55E trans.
Two wheel drive
four door
4.0 SOHC
5R55E trans.
Two wheel drive
four door
