Fireside3
- August 30, 2010
- Texas
- 2001 Sport
00.5 Sport
4.0 SOHC
5R55E
200k+
Using my cousin's laptop running IDS and a VCM.
Just replaced fried PCM with same PN and calibration code TTY2. Old PCM was not giving reference voltage to TPS, etc. Was having flashing O/D light and up-shifting issues about the time I was troubleshooting and replaced fuel pump. Figure I fried something when testing this intermittent fuel pump, etc.
Using IDS/VCM was able to diagnose on drive test that when in auto it shifts as such:
SSA (on) - (1st)
SSA & SSC (on) - (2nd)
SSA & SSB (on) - (3rd)
I presume it attempts to shift to 4th here, as SSA, B, & C all switch off, and it seems to drop back down into first. I assume based on the Transgo charts I have seen that TCC solenoid should be energized at this point, but it shows 0.00% and flat-lined on the datalogger screen.
Also nothing showing for the SSD/CCS. Not even an on/off on the datalogger solenoid drive test screen...as if the diagnostic doesn't recognize that the SSD is even there. I am getting a variable output for the EPC though so it's working.
So I guess I have no TCC lockup.
There is engine braking in man 2.
Seems that there is some in man 1, but not as much as in man 2.
I would think the VB gasket issue, but I think it more than coincidence that this happened the same time as a failed fuel pump, and because I can't see the TCC solenoid turning on in the diagnostic test. I can manually energize it though and I hear it clicking. This would probably be likely no ground signal from PCM right?
Perhaps I new a new calibration on this PCM is needed to match up with my truck? Apparently the new (used) PCM came from an 04. Mine is first run of the 01.
Stall test was around 2500 rpm or less at WOT in all gears.
Can anyone familiar with using IDS/VCM tell me if I can use it to force solenoid switching, or only monitor outputs? The test prompts on the drive test say they can be switched using an OCS (output control state?), but I don't know if that's a separate component from this tool.
Also...I seem to have a completely different PCM pinout from the ones shown on this site for a 2000 4.0 SOHC. Mine has pin one starting at the bottom-passenger side, rather than at the top. The pins go up in sequence from bottom to top, left to right (as you are looking under the hood toward the rear) rather than from top to bottom like the pinouts I have seen posted here. WTF? Anyone clue me in on that one?
4.0 SOHC
5R55E
200k+
SSA (on) - (1st)
