Tommylee1282
- March 30, 2014
- Manville, NJ
- 1999 Ford explorer xlt
2007 4.0 5r55s dropped the transmission pan and changed the filter last night, went to refill it, put 5 quarts in, turned the truck on, waited 5 minutes pulled the hose off the refill adapter and only drops came out. I put another quart in and still only drops came out. I was expecting it to pour out in a stream from what I’ve seen on YouTube. From dropping the pan and changing the filter i got just under 5 quarts. I cautiously drove it around the block a few times after letting it idle for fifteen minutes and seemed to be driving the same as before.
did I under/over fill the transmission?
From the videos I’ve seen you run the truck for about 5 minutes to get to 80-120 then pull the hose while the truck is still running? Or do you shut it off?
If I overfilled the transmission by a quart will I have issues?
thank you for your help
