5R55W to T-5 Swap | Ford Explorer Forums
5R55W to T-5 Swap
cjoslim
San Juan P.R.
Merc Mount V8 2WD yr02
Hey guys been a while since i've been wondering around here again.
Anywayzz
I have a Mercury Mountaineer in my garage and its proximate to a almos hole tear down sinc eit has many things to fix like the Differential(leak) engine heads sounds like a hurt valve and etc etc.
in the
TO DO LIST:
its one of thefollowing since.. i have many bad experience with this 5R55W tranny i'm going to make my own SUV STD with a T-5
MY WONDER IS!
is it possible to me to get a junked Ford mustang that has my same engine
ROMEO 4.6L V8 16Valve or 2V engine,
and swap the clutch and transmission system into my Mercury?
i'm starting off this thread, as the same time i'm going to start my reasearch homework checking into service manual to see if the engine has same bolts and such
ANY ADVICE WILL BE VERY
veryyyy
apretiated :) since i think i would be the fist Mercury Mountaineer STD in PR..
and probably buy a twin turbo kit or a Saleen blower
So.. i guess i'm on my own then :s
Anywayzz
in the
TO DO LIST:
MY WONDER IS!
veryyyy
4.6 V-8s are all basically the same. But, certain differences exist in some things like exhaust manifolds, tuning of the engine (different injector sizes, etc.), so the computers are different. You would need to take special notice of those differences, and use the necessary specific parts off your Mercury engine on the replacement engine. imp
Edit: BE SURE the replacement engine is NOT of the Double Overhead Cam type, before going any further. BOTH DOHC and SOHC were used in Mustangs......
TO DO LIST:
T-45 not t-5. The t-5 was used with the 5.0l.
The 4.6l, starting in '96, got the t-45.
Then, 4.6L clutch housing bolt pattern is DIFFERENT from 5.0L? imp
Yes, the 4.6l, 5.4l and 6.8l(v10) mod motors use a different bolt pattern then the windsor motors.
Thank you! A good thing for me to know....Do they match any other older Ford blocks?
In the day, the big, round, back-end of Ford FE blocks was all alike, from 332 to 430 cu. in. imp
Ford Flathead engine pattern
* 221 V8
* 239 V8
* 255 V8
Lincoln Y-block pattern
* 317 V8
* 341 V8
* 368 V8
Ford Y-block pattern
* 239 V8
* 256 V8
* 272 V8
* 292 V8
* 312 V8
Early MEL pattern (1958-1960, Same as FE)
* 383 V8
* 410 V8
* 430 V8
Late MEL pattern (1961-1968)
* 430 V8
* 462 V8
FE Gen 1 and Gen 2 pattern
* 332 V8
* 352 V8
* 360 V8
* 361 V8
* 390 V8
* 391 FT V8
* 406 v8
* 410 Mercury V8
* 427 V8
* 428 V8
Early Windsor V8 pattern
* 221 V8
* 260 V8
* 289 V8 (made before August 3, 1964) - had five bolts holding bellhousing to block
Later Windsor V8 pattern
Note: this is commonly called the Ford Small-block V8 pattern, though it is used in some "big block"-sized V8's as well as some V6's and I6's.
* 200 I6 1978-1983 only, partial (4 of 6 bolts) pattern.
* 250 I6
* 255 V8
* 289 V8 - (made after August 3, 1964) - had 6 bolts holding bellhousing to block
* 302 V8 including Boss 302
* 302 Cleveland (Australia)
* 351 Cleveland V8 (not the 351 Cleveland M-block engine)
* 351 Boss
* 351 Cobra Jet
* 351 Windsor V8
* 400 Cleveland M-block V8 aka 400FMX (certain 1973 casting numbers D1AE and D3AE, mated to the FMX transmission)
* 3.8/3.9/4.2L Canadian Essex 90° V6 (RWD only)
* 240 I6
* 300 I6
* 4.6L Modular V8 (first two casting runs, numbers F1AE and F2VE)
* 5.0L V8
* 5.8L V8
335/385 Big Block V8 pattern
335-Series (M-Block)
* 351 Modified M-block V8 (Not to be confused with the 351 Cleveland which uses the small block V8 pattern)
* 400 V8 (except some 1971 and 1973 late Windsor-style castings)
385-Series
* 370 V8
* 429 V8
* 460 V8
* 512 V8
Taunus pattern
* 1.2/1.3/1.5/1.7L Taunus V4
* 1.8/2.0/2.3/2.6/2.8/2.9/2.9 Cosworth/4.0L Cologne V6
Falcon Six pattern
* 144 I6
* 170 I6
* 200 I6 (through 1977; 1978-1983 have partial late Windsor pattern)
Early OHV Six pattern
* 215 I6
* 223 I6
* 262 I6
UK Essex pattern
* 2.0L Ford Essex V4
* 2.5/3.0L UK Essex V6
Pinto EAO I4 pattern
* 1.6L/2.0L EAO I4
Pinto OHC RWD pattern
* 1.3/1.6/1.8/2.0/2.3/2.5L OHC I4 RWD
Vulcan V6 pattern
* 2.3/2.5L HSC FWD I4
* 3.0L Vulcan V6 (FWD and RWD)
* 3.0/3.2L SHO V6
* 3.8L Canadian Essex 90° V6 (FWD only)
Duratec pattern
* 2.5/3.0/3.5L Duratec V6
* 3.4 DOHC SHO V8
Modular V8 pattern
* 4.6L SOHC/DOHC V8 (later castings, F3VE and up)
* 5.0L Coyote DOHC V8
* 5.4L SOHC/DOHC V8
* 6.2L Boss SOHC V8
* 6.8L Triton SOHC V10
So i can look for Any 4.6L 5.4L or V10 vehicle and i can be able to make a tranny swap
from my 5R55W to a (Correction) T-45
Thanks for the info! :D
I've been trying to find a 96+ mustang or F-150 having a 2valve 281 engine to make it happends
Also been trying to find info about Volvo since they say the are similar and ppl used to attach Ford's 302's into those volvo and will fits great
Also Got a friend offereing me 2 cobra heads
since a guy asking him to fix them and he never came back to pay the 350$ job and he tould me u gve me $300 and their urs.. and ...
im thiking it since i would need to find my self how to adapt it and find a intake manifold and sush... and all thosse sensor and crap WOW just find it a bit .........
just preffere to do a turbo i think is easier and maybe cheaper and more fun
than having a 32Valve V8 281 SUV
IMO the easiest way to do an engine swap is to buy a smashed donor vehicle with the drivetrain you are looking for (mangled stang maybe) and then you have everything you need: wiring harnesses, computer(s), transmission, rad (maybe if it's not trashed), driveshaft yoke etc etc.
Good luck with your project!
So.. True....... Guees what! just what i was expecting so my time is kinda of running up!! :(:(:( my tranny is acting stupid ... and drags.... it just sucks an dI aint fixing a crappy tranny .... y prefer buying any other car since it will just end up broken again...!! :(
I luv my Mercury Mountaineer but.... tranny is just to much to handle... swap to a Manual tranny
thinking of finnding a 99-03 4.6L mustang to get the job done....
what make sme think is the part of the clutch pump assembly & pedal
saw a Few days ago a 94 Explorer with a 5.0 Manual trans
my eyes teared of joy..! he put 1rst gear and left switching gears happly ever after. i went into depression when i got in mine LOL
