ok, in attempting to remove the extender pin, i broke the tip of the servo shaft off. I had a spare servo so i installed it. The fluid in the trans was dark, smelly and had some metal flakes in it. (mind u i probably only dove the car with the extender pin installed 10 miles) When test driving, there was no change in trans function. It goes into reverse on a small delay, you can feel it go into Drive but the car wont move when u accelarate, shift into 2 and the car goes, after u get to about 2000 rpm u can manually shift into OD and the car goes through its shift sequence just fine. Come to a complete stop in OD and then accelarate, the car wont move. Put it into 2 and it will go.
Oh and the z link was fine, but the hole that the z link fits into in the valve is a bit oblong and presented some sloppy function, dont know if its enough slop to matter.
What shud i do now?
