sailor1968
- May 17, 2011
- Mayflower, Arkansas
- 93 xlt
I recently installed a new fuel pump and for the last month or so it has worked fine. Recently I have had a problem with it stalling at stops and dying. I can usually restart the engine and then when I push the gas pedal it wants to spit and sputter sometimes it just goes and sometimes not. Can I check the pressure regulator or is it a fuel pump? I only changed the original because the float did not work.
