KBoomBoxx
- November 16, 2005
- Stanardsville, VA
- 1994 Ford Explorer XLT
Recently, actually 3 separate times over the last few weeks, my car has given me the same issue. When I go out to start it, whether its already warmed up or not does not matter, it wants to start, but it seems like its not getting gas. When you turn the key it sounds like the fuel pump is not always kicking on.
Heres the situation: turn key, turns over, car starts to shake as if its not getting enough gas, step on gas and floor it, but no change in idle, car dies out. Restart car, starts for 1 second and dies out again. Repeat process several times. Turn key and do not hear fuel pump turn on. Eventually it will start and be fine. My thought is that the fuel pump is starting to go. Today I popped the fuel relay out, cleaned it, and it started right up. I am thinking that I reset the fuel pump which is why it started, but that it is starting to go bad.
Any thoughts?
I found one at the local auto parts store for $110. Good price?
Any thoughts?
