Happy Jack
- June 5, 2004
- Wichita, KS
- 94 Sport
Took it to the shop again this mornin and the guy asked if I researched this so I figured I'd post. Gonna be a little long. Bought it 3 years ago north of philly and it was a Jersey truck. Had the original one core radiator and M5OD in it. AC did not work and I drove it back to KS. Fixed ac and had the cooling system cleaned with BG product. Installed 2" lift, changed axles from 3.27 to 3.73 and added a rear locker. Warn grill guard and 9500i winch. Always had trouble running warm with the ac on. When the M5 went bad I installed a c-5 and T&M Doubler and went to 33 10.5 tires. I installed a new 2 core radiator. Had lots of issues with tranny heat and had it replaced with another c-5 (both were rebuilt but by different shops). Still problems with tranny heat and had the radiator bust and mix atf with coolant. Replace the radiator with newer 2 core auto one. Took the auto and doubler out and went back with the original M5 after a local rebuild. Droped back to 31" tires Has new radiator, water pump, thermostat, fan, fan shroud, fan clutch.
What it's doing is running hot enough to cook the hood (paint starting to orange peal) and vapor lock when push hard or long enough. Worse with the AC on. Last month went to Colorado to camp and wheel. Loaded it heavy with gear and stuff and headed west. Ran fine in the morning. In the afternoon when it got hot and I started climbing the temp needle started climbing. Started to smell a strong caustic gas oder. This had happened before on a trail with a very long steep climb and is usually followed by hard starting if I shut if off. Have had the smell soo strong it burns my eyes and throat and make folks sick. I needed to stop so I turn the ac off before I arrived at the next town. Sign in the previous town had said temp was 103 degrees. Cooled it down to 1/2 way. It vapor locked and would not start. Happens sometimes on the trail when I smell the bad gas smell and turn it off. It will start rough missing and sputtering. I run the rpms up to 1200 and after a while it clears out or if I parked it facing down hill just start down the hill in gear and suck cooler air through the engine. This time it would not go up to 1200 or clear out. Opened the hood and let it cool down for 1/2 hour or so and it started rough and went to 1200 and cleared out. I continued on with out the ac. It got above 1/2 on the gauge and I finally had to turn the ac on for short periods. Done this before. Turn the ac on while going down a while or flat and level and turn it off on up hill sections. Got up in to some cooler weather and rain and made it to camp. Did a few trails. Engineer was no trougle from the Lake City side. Went over Cinammon from the Silverton side (steep side) and the temp climbed with no ac on and I get that strong smell and it runs rough. 5 days later we go up the Silverton side of Stoney (steep and long) in the cool mornin with fog and rain and it heats up again.
The temp gauge has a large normal area. The NOR is the lower half of the normal range and MAL the upper half. There are brackets that go above and below the letters. Everything seems to be fine if the temp gauge stays in the NOR or lower half. Problems start to occur at the A and L. When it hits the upper part of L I start to try to cool it down. Turn off the ac. Slow down to 55 or less. The temp will drop when I slow down going through a small town.
So ideas? Running lean maybe? Timing? Gas out west is 85 oct. and 87 around where I live. I'd just like to be able to drive it out west in the summer with the ac on and wheel it in the mountians. Sorry for the long post.
