95FordExpXLT
- February 12, 2006
- Saxonburg, Pennsylvania
- 95 XLT
Today, I tried to shift into 4wd and the switch illumination backlight went out as soon as the switch went to 4wd, and the dash lights started flashing (6 times) and had no 4wd. Later in the day, I checked all the fuses and re-seated them and everything appeared OK. Now it will shift into 4wd as tested in the garage, I could hear the shifting into both 4hi & 4lo, shifting from neutral back into gear. Taking for a test drive, it would not go into 4hi unless at a complete stop and moving back & forth from neutral to drive.
It will shift out of 4hi back to 2wd while driving, but not into 4wd. 4lo appears to work as is supposed to, only going in and out in neutral.
