    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
96 EB 4wd - Front driver side wheel does not rotate freely?
Godzilla2y
Cleveland
1996 Eddie Bauer 4.0 4WD
I finally got (almost) everything on my Explorer squared away. It reliably runs and drives now, so that's good news. But after putting it up on a lift, my FIL was concerned that the front driver-side wheel does not rotate freely.
We could rotate it about 30 degrees (approx) in either direction before the rotation hits a very sudden stop.
Putting it on the lift in drive and in 2wd, this wheel would not rotate with the rears.
Putting it in 4 LO and 4 Auto also did not cause this wheel to rotate.
My FIL believed this meant the front dif was toast, so we pulled the driver's side half-shaft as a temporary fix.
Is my front differential bad? Will I need to rebuild it?
C420sailor
Long Island, NY
98 XLT SOHC, 99 EB 5.0L
So you jacked the entire vehicle, started it, put it in drive, and all wheels but the front left spun?
You’re going to want to reinstall that half shaft. The ~200ft*lbs of torque on the axle nut provides necessary bearing preload. Not having that is a recipe for wheel hub bearing failure.
masospaghetti
Huntington Beach, CA
98 XLT, OHV, 4D, 4x4, 5M
When it hits the "sudden stop" does it stop rotating, or just encounter some additional resistance?
The front differential is open, so with the axle up in the air, it's normal for only one wheel to spin (and the other to remain stationary).
I assume the "sudden stop" is what you feel after the slop is taken up in the gears, and the differential starts to rotate.
30 degrees sounds like a lot but it's about what I have in mine, and it's been that way since I bought it with no problems, I even did some light 4-wheeling without issue so I know the front axle is working.
96eb96
Albany, NY
96 EB V6 OHV 4WD
if he wants to take this route, maybe cut the 1/2 shaft so a stub sits in the axle. 1/2 shafts are cheap. Or even get a used one for a few bucks and separate it.
DO NOT drive around with no 1/2 shaft in the hub. The wheel will separate.
410Fortune
River Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
yes the wheel bearing will come apart within a block or two without the stub shaft in there and torqued to 200 ft lbs
Godzilla2y
Cleveland
Thanks, everyone.
The wheel came to a full complete stop after that bit of rotation. We tried putting a bar in the wheel to see if maybe it was just resistance, but couldn't get it to budge.
Before taking it out, it felt a little sluggish. Definitely better afterwards.
And we disassembled the half shaft and put the end back through the bearing, don't worry.
C420sailor
Long Island, NY
Phew.
If you’re really worried, pull the shafts and drop the diff. Take a peek inside. An afternoon job, soup to nuts.
Godzilla2y
Cleveland
That's what I'll probably end up doing. What should I look for once I end up getting it apart?
RangerNutt
N-half I75
96 Ranger XLT
Have you already indicated the rotor, or backed the pads away to see that it's not warped? There's a pulse feedback through the pedal on braking with warp, but sometimes not detectable if slight. A lot easier to check than getting into the diff (which you might have to do anyway, but...).
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
Reading the first post I think everything is actually ok, normal.
Some cv axles will not rotate fully at full droop, depending on how far the suspension components will drop down, and brand of cv axle.
Being a 3 bearing cv, you'll see about a 1/3 rotation.
With everything together and while on the lift try placing a jack under the control arm elbow extension to raise the wheel about an inch, then try rotating again.
or, leave one wheel on ground and raise the suspect wheel. I bet it rotates if the sway bar is under stress from the opposite side.
Godzilla2y
Cleveland
Interesting, turdle, thanks. What causes it to bind up like that if it's normal?
C420sailor
Long Island, NY
Sounds like the bearings in the CV joints, as mentioned. It’s interesting...I always assumed it was normal resistance in my diff.
Honestly, everything you’re say saying does sound pretty normal...except the ‘sluggishness’ that disappeared when you removed the halfshaft. That’s odd. Sure it isn’t placebo effect?
CDW6212R
Hauls the mail.
Knoxville, TN
98 Limited AWD
This sounds correct. The CV joints have a limited range of motion, if the angle due to the suspension hanging is too much for the CV joint, it can bind and not move. That's what the limit straps are for in the trucks out four wheeling seriously.
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
Sorry I am late to answer but the other guys pretty much summed it up. Any U joint or cv joint has a limited angle. You found your limit. I am pretty sure the only way you would encounter that limit and cause a problem would be when your truck lands from being completely airborne. The sway bar will limit the down travel 99.9% of the time.
Godzilla2y
Cleveland
Finally had some time to ponder this some more. Odometer is broken, so I'm trying not to put too many more miles on it before I fix that (that'll be fixed next)
Anyways, if the issue was the bearings in that half shaft binding up, why would the passenger side rotate freely, but not the driver's side?
masospaghetti
The differential is open, so the passenger wheel is free to rotate even if the driver's side is fixed. This is assuming the transfer case isn't locked.
Godzilla2y
Cleveland
Yes, but the consensus at this point seems to be that it's not the differential causing the driver's side binding
masospaghetti
Correct, and if the driver's CV shaft is binding, it will not prevent the passenger axle from spinning freely. You could have the driver's side tire touching the ground and the passenger axle will still be able to rotate.
Godzilla2y
Cleveland
Why are the bearings in the passenger side axle not binding like the driver's side is?
