Diginick
- December 10, 2018
- Denver, CO
- 1996 Ford Explorer Sport
Hi folks,
The 'ignition switch' or 'ignition lock/coil', not sure the proper name for it, but the thing where you put the key in to start the car lol, has been jamming/sticking for awhile, until it finally got the best of me, and stopped turning altogether with the key in. I had just drove back from work one night, parked the car, realized I needed to go somewhere still, and the key stuck.
-One thing to note is that my power locks have been acting up lately as well, and the same time my ignition locked, the power locks jammed as well (driver side will occasionally get stuck in the lock mode)
Oh and the keyless entry (keypad on the door), stopped working the same time the locks began to jam. But that's not the main issue here...
I discovered it should be a pretty easy fix, where you just put a screwdriver/or push tool in a little hole under the steering column, which will push a little pin inward on the ignition switch, then you can just pop it out with your hand. Sounds pretty easy, except you need to turn the key into the on/drive position (first turn of the key where it starts the battery/radio/ant-theft etc), which I can't even do now. So I can't get out the old switch, in order to replace it.
How to video for reference:
Once I put the key in the ignition, it won't turn at all now.
One tip I received is to just spray some WD-40 in the switch, but I'm not sure, and afraid that might mess with electrical stuff.
How can I get out the ignition switch, if I can't turn the key to the drive position first? I hear some people drill it out somehow, but I don't know if and how to do that either.
Also, I did find there are a few fuses that are for the ignition/and power locks, I'm going to check if those are blown, and maybe replacing them will help me turn the key, and unhinge the power locks as well. Hoping to find some answers as I check the fuses tomorrow, thanks in advance.
-Nick
-Nick
