lugnut1009
- November 15, 2021
- Location
- MS
- Vicksburg, Mississippi
- 1997 Eddie Bauer 5.0 AWD
- Callsign
- n/a
With the valve cover off it may make some sense to check for a timing chain issue. Both valves on cyl #1 should be completely closed on compression stroke when the harmonic balance is indicating TDC. If you are on the passenger side, it's probably #6, but not absolutely sure.View attachment 423945Pulled the intake today. Couldn’t find any leaks or anything at all wrong. Blew out and cleaned everything. Took off passenger side valve cover since it’s the worst side. No problems there. Did another compression test on that side with valve cover off and all plugs out. Still 150 psig on all. Sure thought I’d find a smoking gun here. Even pulled the ECU just to look for bad parts, all looked new inside.
Though it may not apply in this case, I just want to throw this out about O2 readings. P0170 - P0172, especially P0171 - System Too Lean.O2 readings are high, which if I understand correctly indicated a lean condition and adding fuel. And the O2 graphs are cycling up and down and not flat lined so they’re working
A lot of that was RTV sealant from the previous owner. I haven't found any vacuum or intake leaks at all. I put the intake back on yesterday and my next plan of attack is to use a temp gun and see which cylinder is cold when running by shooting the exhaust manifolds right at the heads. My theory now is possibly a failed or plugged injector. Which would explain a miss and the excess air in the exhaust. All of them look to be the factory yellow 19# injectors, the part number on the side of them is F6VE-A5A.This is correct 5.0 firing order
Lean code
Too much air in the system, the computer has attempted to compensate by adding fuel abs was not able to overcome the lean code
Lean condition can be caused by low fuel pressure, bad injector, or by un metered air, any air entering the intakes after the mass air flow sensor
Check the intake plumbing really well
No evidence of leaks at the intake plenum gasket where it meets lower intake?
I would not be suspecting wiring with those codes unless something jumps out at you on the wiring side of things
Looking at the picture you posted above there is a lot of black dirt/ soot on that lower intake where the gasket was.. it should be shiny metal, looks like a leaky gasket no?
I have seen the videos testing them before, and I should have pulled them if for nothing else just to inspect. But I have a test kit and another gasket on the way. So I’ll pull the intake, again, and test them all. Also I want to inspect that big wire bundle that goes right beside the EGR valve to see if I have any bad wires in there going to them.You could have pulled all 8 injectors and bench test/ clean them quite easily
I followed a YouTube video years ago and made an injector tester cleaner using an old tire valve stem and some jbweld. Also cut off an old injector wiring pigtail Now I am able to run carb cleaner through an injector as I open and close it with a jumper
Box or car battery. I can see each injector spray and run cleaner through them. I have rehab many injectors this way. I do this to every used injector before they go into my engine projects. It has become a valuable tool.
There should be no silicon on the upper plenum gasket!!!! Just a dry gasket
The intake elbow gasket and throttle body gaskets should also be checked, it is quite common for the elbow gasket to blow out over time leaving you with large air leak
Already purchased a tool to do this with so no need to fabricate one. Thanks for the heads up though.Get a valve stem, carb cleaner red straw and some in weld make the tool now so the job weld has time to cure
Don’t listen to that guy. All 5 of my 5.0 trucks are custom exhaust without cats. As long as both front 02s are present your just fineNot even in open loop at initial startup? I thought the 2nd set of O2’s were only measuring the efficiency of the cats. I wouldn’t have removed them, but I got it this way.
Also I’ve checked the EGR valve, it’s operating properly, and purchased a new IAC valve, waiting on the throttle body mounting gasket before I put all that back on.
Did you disable the Bank 1 and bank 2 O2 sensors after the non existent CATs? Also remove the DTCs for those O2 Sensors. This way your fuel trims should reference the 2 existing O2 sensors. I would expect to see a noticable improvement. Sometimes people just take the CATS off and expect a miracle to happen when it comes to performance. They don't realize it is all tied together in the program. Best of luck.
Stop posting incorrect info, you can in fact drive just fine without cats and a tune. All 5 of my explorers prove that. The pre o2s are required for fuel and air the post are only there for cat functions. That’s your o2 lesson of the day. Thanks for trying. A miracle does happen you gain power and free flowing exhaust and the rears are not tied to fuel trimDid you disable the Bank 1 and bank 2 O2 sensors after the non existent CATs? Also remove the DTCs for those O2 Sensors. This way your fuel trims should reference the 2 existing O2 sensors. I would expect to see a noticable improvement. Sometimes people just take the CATS off and expect a miracle to happen when it comes to performance. They don't realize it is all tied together in the program. Best of luck.
