Fraser
- September 6, 2007
- Peoria, IL
- '97
First time poster, looking for a little help. I got my hands on a running 97 Explorer with a 5.0L/302, auto tranny and single speed transfer case (AWD) that had been rolled. I removed the engine, transmission, t-case and all the wiring, and put the engine (and wiring) in a rock buggy, bolted to a T-18 manual tranny and Dana 300 t-case. It's now running, but of course with the original auto tranny missing, the check engine light is on. I pulled the codes and found P0750, some transmission issue, which I expected. But also there was a P5507 which I haven't been able to diagnose, and that's why I'm posting. Anyone know the answer or have another source I can check?
If I find out the P5507 is also tranny related, then I'm not too worried, but I do want to know what it means.
With the exception of the two wiring connectors for the transmission (and all the other stuff I don't have like power windows, locks, mirrors, ABS, radio, hvac), everything else is connected (as far as I know), all four O2 sensors, charcoal canister, evap stuff, etc. While I'm still in diagnostic mode, even the original Explorer dash is still hooked up. All the gauges work except for the coolant temp, however the scanner picks up the coolant temp, about 203 after it's been running a while - could the lack of a reading on the gauge be a clue?
One other possible clue - my scanner showed a calculated load of about 40%, and that's at idle, around 700 rpm. I would expect the load to be about zero, or close to it. I checked vacuum and found about -18psi - seems ok to me, but not great, is that normal for these engines? It has about 130k miles on it, so I'm sure it has some wear.
It wouldn't surprise me to learn I'll need a computer from a manual tranny Explorer in the end. Was the Explorer ever offered from the factory with an OBD-II 5.0L and a 5-speed?
Lots of questions, may be in over my head a little. Thanks a lot for any insight.... Fraser
