- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
OKay here we go again....hahaha though all my problems would go away with the new 5.0L drivetrain, but NOOOOOOOOOOOOOOOOOOOO there are still some bugs.
I have been getting transmission sensor codes and also 02 sensor codes lately. The most common code I get is P0705, and P0135
705= digital transmission range sensor
135 = heated os sensor circuit failure, bank 1 sensor 1
After speaking with Baumman engineering (4r70W masters) I believe the 705 code is coming from the DTRS, when the computer sees a signal that is sent between P and R, their TCS controller ignores this signal because it means nothing. Ford issued a TSB for my 97 PCM to solve this issue. This leads me to believe my donor PCM has never had the updates performed.
The 135 code makes no sense at all because the sensor is new, wiring checks out, and I get the same code even if I install a new sensor.
recently the truck has lost OD intermittantly on the highway, now the OD OFF light is flashing.
I cannot pull any OD codes from the PCM.
My question is, anybody had similar issues with a 97-00 Explorer 5.0L?
All my research is pointing me towards having my PCM re-flashed at Ford, I hate stealerships, but of course I want this fixed. Cruising along at 75-80 MPH and the truck going into 3 from OD = no good...can you say red line?
Just looking for input from people who have experienced similar conditions.
Also I am aware of the updated shift solenoid mods for the 4R70W, this would be next after I eliminate possible PCM re-flash issues.
Any input is appriciated, thanks!
