brandon7117
- February 1, 2014
- Georgia
- 1998 explorer 4.0 sohc
I have a 98 4.0 sohc I recently did timing chain job and had the motor out. Since then the heater controls haven't worked. To the point I think I figured out the problem The red vacuum line that goes above right hand valve cover what line does it hook to? Also the vacuum pod thing on top of the upper intake plenum where is the vacuum line that goes to it. Its never had anything hooked to it. Ill take pics tomo if needed.
