- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Ok, ill get it cleaned up and get more pics also how do i go about picking out the seam sealer without damaging things?
I suggested pulling off that obvious piece of seams sealer because it's not stuck to what's below, seeing if it's bad or not underneath is important for the future repair and paint.
You just want to seal up any exposed metal to slow any rust, until you can get it fixed right. I'm curious of how far under that crack it has let go, seam sealer is a poor product to put onto any bare metal. I used it over my clipped joint of my 99 body, after it was ground enough to spray with epoxy primer. There are products which are great for the treatment of bare metal prior to paint etc, the OEM doesn't use those in new production; the seam sealer goes right onto bare metal seams.
FYI, avoid silicone, that's great for making an aquarium, but it's bad for outside a car body. It interferes with paint like you here of Armor-all, creates fish eyes. Just use any RTV, which is not the same but is available in many colors besides clear, and some is cheap. Silicone gets hard and brittle fast, in sunlight maybe six months. I wouldn't use Ultra Black either, those top end products can be very tough to remove.
