rednblk
- December 12, 2011
- Charlotte, NC
- 1999 Ford Explorer 4x4
I have a 1999 Ford Explorer XLT 4X4. it just hit 150,000 miles. It belonged to my wife and her ex before we got married and was parked about 5 years ago when the transmission started to fail.
I recently had the transmission rebuilt, and now I am having issues with it still. First of all we cleaned the fuel tank, replaced the fuel pump and filter, jus to get it to the shop for the rebuild.After the rebuild it ran great for a week or so, then all the sudden I could be driving and have no acceleration at all. rpms would stay at about 2000, and no amount of pushing the accelerator would change it. The problem started out as only at highway speeds and has since progressed to making it almost undriveable.
I had done the following before taking it to Ford:
I then decided instead of randomly replacing parts to go ahead and pay 89.95 for my local Ford dealer to diagnose the problem. Aside from wanting to charge me 250.00 to replace 6 plugs, they said I needed new wires and the coil pack was bad, firing more than one cylinder at a time under load, but they could fix it for 450.00! I am a former Track Vehicle Mechanic, so I figured I would do it myself... Pending codes for both left and right bank o2 sensors.
problem went away for 1 day, then began again. Took it back to Ford Last night (made appointment)and they pretty much told me the parts I bought were junk and alluded that they had no interest in doing another diagnostic til i bought THEIR parts. So I left.
Went home and put a fuel gauge on. ran it over an hour, accelerating, running a/c doing whatever.Pressure was 55 the whole time. Car wouldn't hesitate. I blocked the wheels, put it in drive and within ten minutes it started missing and eventually stalled.
If I am driving I can sometimes shift into neutral, turn off the engine , coast a bit and restart it it and go another mile or so or up the next hill. then it starts again. Problem seems to only occur when driving, after car heats up for a while. it is definitely missing as the engine starts to shudder just before loss of acceleration.
I am at my wits end with this. any help would be appreciated.
- replace fuel pump
- replace fuel filter
- clean throttle body
- clean maf
- clean iac
- replace pcv valve
- check with carb cleaner for vacuum leaks
- gapped plugs to .054 and installed motocraft platinum plugs
- replaced wires
- replace coil pack
