2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
not on mine
I just happened to start pulling out my instrument cluster this week to install some dash gauges (boost & oil pressure), fix my gear selection indicator, and replace a burned out airbag light. I looked all around my light switch and dimmer module and didn't notice anything like the component in the photo you posted. It resembles a voltage regulator. I should get the cluster out this afternoon and I'll get a better look then. My Sport is an economy model and doesn't have any of the options (remote start, keypad entry, message center, EATC, outside air temperature, power seats, etc.) so that may be associated with an option I don't have. If you can identify the wire colors attached to it I'll look it up in the wiring diagrams.
