- October 6, 2008
- Location
- Va
- chesapeake virginia
- '96 xlt 4x4
IIRC, on the OHV, the heater valve vacuum line originates at a black plastic vacuum reservoir sphere under the coolant recovery tank and above the wheel well. Mine is a hard line, grey in color. The SOHC might be the same/similar.
Could be wrong but that vacuum reservoir might be only for 95/96 ex with CAD.
I'll check on mine when I get home and post a pic of where that vacuum line goes if you didn't figure out by then.
Also I'd if the heater core feels warm and there is not even the slightest change in temp when you turn the cold hot knob then blend door sounds likely if it was working then you should feel some difference.
And becoming elite explorer,a big reason why I did it is because they (explorer forum) hosts your image or video or whatever and it's super simple with a phone plus you get a lot lot of other benefits worth every penny of the $20 a year. Otherwise you'd have to have a third party imaging account and put in url to pic to post them here
