rc1626
- January 31, 2002
- Long Island, N.Y.
- 99 Explorer XLT
A/C stopped working on my 99 5.0 Explorer about a month ago. Compressor stopped engaging. I wound up replacing the compressor clutch and now after reading a little feel I probably didn't have to. I read somewhere to back probe the compressor clutch connector directly off the battery to see if the clutch will engage. Sure enough I was able to get it to engage(cycle).
Compressor clutch connector measures 13.5 volts when disconnected from the clutch and A/C on. But when I connect the connector and back probe the connector the voltage drops to zero.
Any ideas of what might be causing this? Pressure switches, relays??? I'm at a loss and any help would be appreciated.
Thanks.
Rob
Thanks.
Rob
