pankodog
- April 19, 2008
- Arizona
- '91 XLT
Stock 91 X w/A4ld: Dropped tranny pan and changed the filter then closed it up and refilled trans, next I ajusted the bands (torque to 120 in. lbs.-back off OD 3 1/2 - back off intermidiate 2) nothing new been here before. So here is the problem--now it is binding up in reverse and in drive almost as if there is a brake on the drive shaft, but if you put it in overdrive it feels and drives normal. I have only test driven about 1/4 mile and I am sure something is going to give if I push it. I re-ajusted the bands again and same result. Very curious! Any one been here?
