A4ld Shift problem 2nd to 3rd only | Ford Explorer Forums
poknox
Hephzibah, GA
94xlt 4wd
I have a 1994 ford Explorer 4x4. When it is cold the Transmission shifts just fine. When It gets to operating temp it overrevs when shifting from 2nd to 3rd. I need to know if there is a band adjustment and how to do it preferably with pics.
There is not a band applied in 3rd. The intermediate band is applied in 2nd, and released for 3rd. Once this occurs the high/reverse clutch is engaged. It sounds like there is a delayed engagement of this clutch. The question is why this clutch is late in engaging. Could be a sticky valve, or could be a seal leak in that clutch pack. It applies in reverse, 3rd and 4th. if it was a leaky seal you probably would only notice it in reverse (which is notoriously slow anyway) and 3rd. Add to that the fact line pressure is boosted in reverse, which may mask any leak. You would not notice it in 4th as it would already have been applied in 3rd. This is a case where a pressure gauge would be a good diagnostic tool. If it is a sticky valve you could fix it in car. Leaky clutch, well... only likely to be fixed with a rebuild.
How does your fluid look ?
ps. if you want pics of a band adjustment procedure, check out the Useful Threads for the "My A4LD Rebuild Diary"
Fluid has about 30000 miles on it but looks as it should. It has started hesitating going from 1st to second a little. My wife says it does it all the time.
