tbe2002
- February 10, 2005
- Longmont, CO
- 08 Expedition Limited
Ok so I decided to rebuild my valve body. I didn't add a shift kit but I did upgrade a couple parts along with cleaning the whole valve body really good. I upgraded the boost valve to the one with o rings. I got the new solenoids mast kit which includes two new solenoids and a sleeve for the 3-4 solenoid. I also got new VB upper and lower gaskets and long with a D ring kit for the reverse servo. Oh and a TCC screen.
I put everything back together with a new Filer and pan gasket. Went for a test drive. It seems to shift really good from 1-3 then you can see the touque converter lock up, but no OD. I was doing 65 at almost 3000 RPM. Anyways, anyone have any clue what the problem could be.
Oh and I did check and triple checked that the wires were pluged in before putting the pan back on.
Thanks for the help guys.
