V8BoatBuilder
Transplanted Bostonian
- November 4, 2002
- East Brunswick, NJ
- 97 Mountaineer V8 4x4
Explorer Express Swaybar Install
The suspension is a part of the vehicle I've wanted to make top notch, especially with the impending lift. The Mountaineer handles turns well in stock form, but after doing hours of research on Explorer Express swaybars, I knew they would be a good mod. When John V announced a group buy, I was sold.
I ordered the front and rear kit, as well as a complete Energy Suspension polyurethane bushing and end link kit for the front bar. Rear bushings are included.
rear
1) Jack up the truck. Remove the spare tire.
2) Remove the lower shock bolt on both shocks. It's much easier to get the impact gun in there with the shocks dangling.
3) Impact away. There is a bolt on each end link, and two bolts on each side of the axle tube.
4) The bar is heavy, don't let it clobber you.
5) With the swaybar removed, it's a great time to change your rear axle fluid!
6) Put the energy suspension lube on the inside of the new rear bushings, and insert them over the swaybar.
7) Bolt the bar to the end links first. Unfortunatley, EE has us reusing the stock ones, which are tiny in comparison to the bar.
8) Bolt up the bushing brackets. Make sure the bar is centered, and install the split collets.
9) Reattach the shocks, and lower.
front
1) Work can be done with truck on the ground
2) Unbolt the end links from the A-Arms, and the swaybar from the front crossmember
3) The bar is heavy, but not as heavy as the new one!
4) Just like the rear, lube up the new Energy bushings before slipping them on. They have a tiny slit in them.
5) I installed the end links without the lower rubber bushing to center the bar first, then bolted it up loosely to the crossmember.
6) I had my father press down on the tops of the endlinks with some scrap wood to compress the rubber bushings enough to get the "under the A-Arm" bushings, washer, and locknut on. Tighten the end links.
7) Center the bar, and torque down the mounting bolts.
8) Get some food, take it for a drive and....
Wow - What a difference! The truck feels much more stable in turns, I can now take corners much faster, and merge more confidently. Less brake pedal, more accellerator!
Overall a worthwhile mod.
rear
front
