ABS light | Ford Explorer Forums
ABS light
wrnoutrnger95
Snellville, GA
'95 ranger
Hello
I have a '95 xl ranger 2wd with a abs light on. So far I replaced all the brakes pads and shoes, master cylinder, abs hydraulic unit (inside the frame under drivers side), rear sensor at differential, and bled the brakes numerous times. Sometimes the light will go off for a while, but it comes back on again if I hit the brakes real hard. It's only rear abs brakes not 4wheel abs. Has anybody had the same problem?
thanks
Joe
...I fixed mine by filling to the proper level...;)
...The sensor is sensitive to the right amount of fluid....A hair little and the light will come on...
