- December 28, 2010
- Russell, Ontario (Ottawa area)
- 2025 Aviator Reserve 201A
- Callsign
- VE3... grid FN25hg
Welcome to the Forum.I've seen discussion on adding fog lamps to base model but not 2017 model. Concerned there is not
wiring already installed to hook up OEM assembly. Also, with all the different lighting types available don't want to have different color bulbs than the other headlights. Anyone have experience with this?
Your thread has been moved to this one on the same topic. I believe the Base has LED low beams so if that is correct you'll want LED fogs as well.
