springer
- November 29, 2004
- Houston, TX
- 2008 MM Premier AWD V8
I have searched this, and found a couple of threads that tell me this is likely a computer issue. However, I wanted to reach out for advice to make sure, and also on purchasing a remanufactured ECM or sending mine out for repair.
Background:
The issue started day before yesterday. The Merc seems to be running fine - its my wife's DD. She thinks it runs the same, I thought it was fine when I tested it.
* Battery is new (January 2021 - Optima Red Top) At the battery, I am seeing 12.5v when static, and 14V when engine is running
* fuses 38, 42, all the 15a fuses on that row are fine & have power on both sides when the ignition is on.
* I have a cheap scanner & can clear the codes. They come back, but not right away. For example, I cleared the codes, then drove it around the neighborhood (probably 1-2 miles) & the codes did not return. Then my wife drove it on errands, made one stop, no codes, then codes came back when she started the car to leave. (only parked for minutes). Another time, the codes came back mid-trip (while driving) - that seemed odd to me as I assume the O2 heaters are part of start-up.
* Visually, I do not see any wiring issues. All wires (that I can see in a non-invasive inspection) look new and unscathed. (I have owned the car since 2008, it was a Ford Executive Program Car (original owner for less than a year) and I have done all the maintenance. No major issues.
* I replaced all 4 O2 sensors as part of routine maintenance at 100k, the Merc now has 150k. I think I bought Bosch O2 Sensors.
* Also, I dropped the spare and looked at the vacuum lines going to the filler door (capless fuel filler) and aside from being dirty, look fine. I don't see any cracks or obvious leaks.
I understand that it could be a wiring issue, but I highly doubt it. Also, I cannot imagine that (the heater circuit for) all 4 sensors would fail simultaneously, unless it is possible that 1 can fail (short internally) in such a way as to interrupt the other 3. It would also really surprise me that the computer would fail, but I did see an extremely detailed write up of how this can happen and is a weakness of the computer itself, so I am leaning towards this possibility.
So, does anyone have any advice, or is there anything I have not considered? Also, has anyone used a repair service for the ECM that they recommend? I found MODULEREPAIR on e-bay at $250 (ship yours to them for repair) and "Car Computer Exchange" recommended on YouTube, which appears to be $700 and they ship you a remanufactured unit and you ship back your old one.
I can do without the car for a few days or a week, although letting my wife drive my Ford Lightning makes me cringe a little... LOL. The brief search for the computer repair surfaces a big difference in prices, and if I purchase a remanufactured unit (they claim to be pre-programmed), is there any issue with the keys/remotes (PATS) - assuming the keys are chipped ( I thought they all were, but I don't see a chip. I have the two original keys and fobs.)
Thanks in advance, sorry this is long.
--M
Background:
--M
