Air vents are stuck on windscreen | Ford Explorer Forums
Aussie123
Canungra, Queensland
96 XLT
Hi,
No matter what i do, i cant stop air blowing on the windscreen, and i just cant make it blow out of any of the other vents.
Does anyone know what might be wrong? and how i can fix it?
Sounds like a vacuum leak. I had the same thing happen to me this past summer when the vacuum cannister got trashed during a header install. It's not as bad as it sounds. The cannister is normally below the passenger side, under the airbox, If the cannister or lines leading into it are damaged, then all you get is defrost. In my case, the cannister needed replacing. Often it's just a broken line which can be patched easy enough.
The cannister looks like this:
I see Turdle already pointed you to it before I could hit "submit reply". His thread solved my problem too. :thumbsup:
