SyberTiger
- May 18, 2007
- Orlando
- 2002 Limited 4x4 4.6L
For anyone who has changed their EGR valve I was curious to know if you had difficulty removing the EGR valve. I assume you remove the EGR tube first while the valve is bolted to the throttle bottle. Is there any risk of damaging the tube while trying to remove it from the valve?
When installing your new EGR valve do you put anything on the threads of the tube nut? What are the torque spec for the two bolts that hold the valve onto the TB?
2002 4.6L V-8
2002 4.6L V-8
