bipolarbob
- January 29, 2003
- Kelowna,British Columbia,Canada
- 91 Eddie Bauer
There is about 4 different kinds at the local picknpull. Anyone tried?
Dre said:fiberglass? rear lift gate on the "X" is all metal. Cherokee's is fiberglass. If you want to install the tire carrier on the liftgate think about all the extra weight you're putting on. It'll be pretty tough to keep the gate in the open position. On the BII carrier swings out for the gate to open... if you install it on the "X" you won't be able to swing it... no need to do that.
glfredrick said:The tire carrier mounts to the sheet metal along side the lift gate - not directly on the lift gate (that is if you are using a BII version).
410Fortune said:The reason you dont want the tire on the roof is for center of gravity and also clearance into parking garages. Anything over a 33" tire will not fit under the explorer, even the 33" requires some slight modifications to get it to fit....
