sehaare
- October 25, 2008
- Chicagoland, IL
- 98XLT 4WD SOHC,94XLT gone
Been under the 98 auto SOHC for a few days fixing various things. One of the things that I noticed while I was under there is that some sections of the transmission lines going to and from the tranny to the radiator and cooler have been rusting in sections. I bought the new lines but I can't get to the upper fitting on the transmission and because of the way the lines are bent you can't get the lower line out without taking the upper line at the same time.
So I was wondering if anyone has cut out bad section of these lines before and used rubber hose to connect the good sections? I know that rubber hose is used to connect the hard lines to the tranny cooler under the radiator. But I believe those hard lines have barbs on the end. If I cut out section of bad lines there will not be barbs there - could I still get a good seal with just hose clamps on the barbless lines? Not sure of the pressures involved.
Thanks again.
Thanks again.
