HELP HELP! Steering cooler troubles | Ford Explorer Forums
speedo1
Ma.
1995 Eddie Bauer
OK., 95 EB, the hard line coming off of the lower position of my PS fluid cooler is rotting and starting to leek pretty good. I have to replace the cooler , so, do you guys use aftermarket, if so, which one? Is an OEM available? Thanks.
Just to clarify, I know I could use an aftermarket cooler but they come with rubber hose and clamps. The rubber line that attatches to my stock cooler is attatched to a hard line and fitting. How do I attatch a rubber line to a rubber line?
