- April 16, 2002
- British Columbia
- 93 4 dr 4x4 manual XL.
A rear end specialist told me that synthetic oils don`t protect as well as 90 weight oil in your diffs if you get any water in there.
He said if I want to change the oil every time I go through deep water, or sit for a few minutes in over-the-hub water or mud, then go for it. He said 90 weight can handle some moisture better.
Since I work in the oil industry I can vouch that oil can absorb and contain a certain degree of moisture content within it. Some crudes, as much as 1% and up.
I don`t know much about synthetic though. Could it not mix or absorb it, thereby causing rust in the vitals?
I stuck with the 90 weight just so I don`t have that statement eating away at me every time I drive through a stream.
Whaddya know about this?
