Alright, going to get some rims for my X but not sure about a few things. thinking of 17-19" and then get whatever tires needed to make the wheel the same size as the stock ones.
What is offset?
what is the widest you can go?
(somewhere I heard that different rims could cause bearings to wear abnormaly... not sure if this is true or not?)
Do I have to worry about unusual wear on the bearings w/ different rims?
Will using spacers to give a wider stance cause unusual wear on the bearings? Are spacers safe?
Any suggestions/comments anything? I want to get rims but I dont want to screw up anything in the process.
1995 ex limited.
Thanks,
Patrick
What is offset?
1995 ex limited.
Thanks,
Patrick
