Cduncan133
- February 12, 2015
- Fort Wayne, Indiana
- 2004 Ford Explorer
And I ran into a couple problems.
1st problem: My wheels were way overtorqued. They were at least 150 ft/lbs. The last time they were messed with was when I got a rotation and inspection done 6 months ago. Will this harm my wheel/lugs/studs at all?
2nd problem: My brake pads didn't fit. They barely fit with the old clips and didn't fit with the new clips. I took them back and they said it was a match for my vehicle, and 4WD/AWD use the same pads/rotors Now, since I was strapped for time, I didn't particularly do any cleaning, and it was pretty rusted. I will clean it when I give it another go. My main question is, can I file the ears a little bit to get them to fit?
The last problem I had was, when I removed the caliper, I had two lines that were attached to it. Obviously one was the brake line, but the second one looked like a wire and even had some plastic tubing around it. My guess is that it may (or may not) be the wheel hub wire. I just don't know how to remove that wire, because with it on the caliper I can't even tuck up caliper inside the wheel well like most videos I've watched have suggested.
thanks for any help!
