Gnomesayun
- December 4, 2015
- 2006 Mercury Mountaineer
I recently bought a used 2006 Mercury Mountaineer premier. It has the sub and amp in the back, but it didn't work. After a bit of investigation my husband and I found out that the head unit has been replaced at some point with an oem radio that does not have the sub plug in the back. We found another head unit on eBay with the compatible plug in for the sub, donor vehicle being a mountaineer 2008. After hitting click I did some research on the part number (8l2t-18c815-bg) I discovered that they warn of the compatibility being only for 08 and 09 explorer/mountaineers. I understand that the antenna plug may be different. My question is can the antenna just be re wired/harness to be compatible or is the software not compatible with my vehicle?
