Matt- Thanks to you and the others contributing to this thread I was able to put my front drive back in service. I suspected it wasn't working the past couple of years, pushing my wife out of a snow bank couple of weeks ago, I could see it wasn't! I had lights so guessed, for starters, it was the hubs. Disassembled them, man, how do they get so cruddy, they're nearly sealed units!? Nothing was broken so based on your discussions thought I'd explore the 'shim' route. Using the hub/rotor mating flange as a reference plane did some measurements on the cam pocket depth and the cam follower extension, looked like it would take at least a 16th inch shim.(we're all trying to recreate the original cam clearances, wonder what they were?). Functionally it doesn't matter which side of the cam you put the shim on, either behind the cam on the axle spindle or in the hub between the cam follower and the 'plastic' inner gear cage.I chose to put it behind the cam on the axle spindle as there is minimal sliding movement there and therefore less concern on what material you use.I'm out in the sticks so use what's handy, in this case some plastic/nylon? material, about a 16th inch thick, it was the thickest shim I could put in and still get the C clip seated back on the axle spindle. I had no thrust washers installed behind the cam, only the 'splined' washer outboard of the cam.
So far, it's working great, though I haven't a clue whether it was cleaning the hubs or installing the shim that did it.
