axle/leaf location = lift?? | Ford Explorer Forums
g0tink87
NY
1993 XLT
was talking to a co-worker the other day who had in the past owned a 1st gen explorer with a lift. He told me that he had switched the axle from under the leafs to above the leafs, and this gave him almost a 3 inch lift.
Is this something that people do for a cheap lift?
I would normally trust him on these things but figured I would ask anyway.
He does have good credentials as far as why i could believe him....he was in a 4wd club for years and had multiple different trucks and jeeps.
...do a search on here for soa, a.k.a., spring over axle...it's more like a 6" lift and it is not all that easy to do plus you have to lift the front end too...:D
...btw, here are a couple pics to compare too...:D
You said he went from axle under to axle over, but it's the other way around. Your explorer is already axle over the leafs.
Wake up mounty
Edit:...sorry for that post...i thought you were out to try and correct me again...sorry, reflex action...:D
yes i did confuse myself when i was typing..lol.
But I'll do some more searching because 6 inches is a lot more than what i want.
I really only want to do about 2-3 all around. And i dont wanna burn a hole in the wallet either.
btw thanks for the pics
ahh thanks for the great link....I might have to consider this. Seems like a good way to lift my truck on a budget.:thumbsup:
i just made some custom shackles from a guys blueprints they were 10 3/4 inch's long how high is that gona lift my explorer up? and where can i get f 150 coil seats?
...remember, the search button is our friend...:D
Those are pretty big.
Stock shackles are 5.5 eye to eye. Warrior shackles are 8.5" long eye to eye and give you ~1.5" of lift.
So, 10.75 - 5.5 = 5.25 / 2 = 2.625
Roughly 2.625" of lift with your shackles, if your measurement is eye to eye.
And you'll need to shim the pinion back down after the shackles are down. Prob a 4* shim but dont quote me.
Do a body lift. You'll be much happier in the end.
