jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
I just did the b2 tank swap and put 2.5 gallons in it.the gauge reads little over 1/4 tank.I know that's wrong.drove about 20miles just to see if it would read "e" and it never did.It started to run out of gas so I know there is about a gallon left the pump can't pick up.then I put 10 gallons in it and it reads just above "e"
Thought the b2 sender would work with the ranger gauge? Or is there just something wrong with the sender? How would I go about testing the sender? Like if I put a volt meter on it what should it read at empty and full to work with a ranger gauge?
This is in my 94 ranger and tank/ sender I believe is from a 90 b2
