Gatekeeper
- May 5, 2010
- Glendale, AZ
- 1996 2wd Eplorer XLT 5.0
I have a 1996 Ford Explorer 2wd 5.0
I have a very bad vibration from 50mph+. The shake can be felt in the steering wheel but really its shaking the whole truck. I had the tires balanced the alignment isnt off much. I replaced the front u-joint on the drive shaft thinking it was worn but the drive shaft still moves up and down quite a bit between the splined slip yoke and the transmission. Could this be the issue? How much play is allowed? Also, when shifting into gears in gives a kick... Any ideas?
