You don't need another chip because I'm assuming you also got the BBK computer with the adjustable timing.
Doug is right that you'll need a new fuel pump. Instead of getting an inline helper pump I decided to go with a new high flow in tank pump. You will also want new spark plugs. I use Motorcraft plugs gapped to .048, but one heat range cooler than stock. I just use Motorcraft plug wires.
You'll also want a good aftermarket air filter and good exhaust. For exhaust, you at least need a new catback setup; but a full system would be better: headers, high flow cat, wide open muffler, and 2.5" tailpipe. I also have 2 inline resonators in my exhaust system to keep the bumble-bee noise away.
You'll also want the BBK 66mm throttle body and a larger MAS (Mass airflow sensor).
Good luck and welcome to the club! I have many threads on my supercharger install and experiences in the Need for Speed forum. In fact, I'll move this there.
