been busy - major surgury | Ford Explorer Forums
rich uk
surrey
1998 sohc 150k Purple LPG
:thumbsup:good news ....did oil/filter change - changed fuel pump/filter - fitted that recon valve body..fitted new seals low / reverse servo....fitted drain on trans sump...changes gear amazing (when it goes into gear) - torque converter seems quieter on the move--still chatters at idle ...
:thumbdwn:bad news - still delays and or wont go into drive ....still leaks trans fluid all over the cat despite a whole load of blue gasket and new gasket ..arghh (bent sump)... slight leak from engine sump...ill look tomorrow ..::)
trans sump
hi rich i will have sump/pan for auto trans next week if you want it. cheers chris
Cheers Chris
I have a spare sump in my gearbox parts shed.. lol
been in there again today .... mmm genuine ford gasket £19.....
is there a spring behind the forward/reverse servo?? ill be searching there isnt one in mine ...
spring
hi rich just had a look in the transmision manual no spring for low revers servo.cheers chris
