- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
New track bar angle (sorry for the crappy picture):
The pictures of the track bar frame mount did not come out very well so I will have to post some later. It is very sturdy and supported with a gusset on the frame and 1" .120 wall DOM tubing from the inside of the mount to the engine cross member. I could not go all the way across to the other frame rail with the tubing as the mount sits directly in line with the steering box's pitman arm mount. With the tubing welded to the cross member, I can still access the nut on the steering box, and the motor mount bolt.
Made some screw-on spacers for the radius arm bump stops in 1/2", 1" and 1-1/2" lengths. That way, I can pick the best bump for the suspension on the next off road trip, then weld them on when I get home.
Also did a little wiring, supported my 1999 Explorer intake at the alternator mounts, and put a bump stop in the center of the engine cross member (I could see a spot where the top of the pumpkin contacted the cross member).
A guy from Pirate who was doing a SAS in his Silverado with a F-150 axle came by and bought my old F-150 radius arms. He said he was going to use Ballistics shock hoop kit. I showed him the one hoop and all the hardware I did not use from the Ballistic kit I bought. He bought those too. He was military so I low-balled myself on the pricing.
