I got the gas can holders and the tables all finished today. Not sure if I am going to like the tables. They don't take up any storage space, but to make them as sturdy as I wanted, I needed to get fancy with the rests. Here is what I came up with;
The bolt is screwed into a weld nut. It takes about a minute to set up both tables. Its not the setup time I don't like, its the fact that they are steel and will flex and be noisier than the wood table I had before. I am also not sure I like they way they look back there. With both of them, I am only gaining about 15" of work space from the old table because of space limitations on the bumper. I might go back to the old wood table that is much longer, and add a second, narrow table for the other side. I can figure out a better way to secure them in the Explorer when I add the shelf/raised floor for extra storage. The fold down tables are neat, and kind of cool, but I am just not feeling as good about them as I thought I would. I need to see how it goes on this trip and decide when I get back. If I don't like them, it should take me about 30 minutes to undo what took me two days to do.
More pictures.
Folded down
For reference, my Coleman double burner camp stove fits on one with about an inch left over all the way around. Obviously, I am not using it on the side with ten gallons of gasoline a few inches away.
Folded up
I didn't get a picture, but they are very secure when folded up. I used the bump stops I have mounted to the back of the tire and gas can carriers as fasteners. You can see the location of the gas carrier bump at the top of the triangle shaped main support. I unscrew the bump, fold the table up, and screw the bump back into the carrier.
Tables folded and extra gas carrier added
I really like how the gas can carrier came out. It takes me about five minutes to add or remove the extra can, depending upon what mission type the Explorer is undertaking. I might make another one for a water jug, but the six gallon one I have fits nicely behind the passenger seat. The cage holds it in tight against the back seat, and I can tilt it out the R/R door to get water.
Added a few gussets to the bottom of the triangle support, even though I used to have two cans on that same mount for several years with no issues. I figured, what the heck, more triangulation..
