That does seem like a very short lifespan in running-hours. I agree with CDW that more investigation could be useful, including the fuse, relay, and speed switch.
That blower resistor, normally the blower would still work on high, but you can just jumper between two (of the 4) wires going to it, to complete the circuit for the fan. I "think" (maybe) the two wires to jumper are on the opposite ends of the connector, orange/black and red/orange wires.
Also on the resistor assembly there is a resettable thermal fuse, and with age they can fail, or in some cases when they trip, they won't reset until power to it is turned off... it's bullet shaped and will read low resistance with a multimeter if working and reset, though with tarnish on it you might need to clean off an area to get a valid multimeter reading.
If you end up committed to buying a replacement blower, one last thing I'd do is autopsy the old blower first. Maybe it can't easily be opened, might need spot welds drilled out or something, but if it turns out to be easily repairable, might be able to bolt it back together. Examine bearings, brushes, commutator. When they get very old it is common for the bearing, or really I mean bushing to dry out but it shouldn't have happened in this short a period unless the factory skipped the step of loading it with oil. Regardless if it has resistance turning, either something very bad happened to the brushes or the bushings just need cleaned out and oiled. There are other things that can lock it up like core laminations flying apart but it's far less common. You can power it on a bench with a cordless tool battery if nothing else, the few volts higher won't make much difference for a short period of testing.
If it turns out that the thermal fuse in the blower resistor has failed, could be overheating from partial airflow blockage and time to check air passages and make sure there isn't a clog from leaves, seeds, or some critter nesting in there.
Wiring diagram attached. If I've got it wrong and you have the automatic EATC version, get the full pack of wiring diagrams in my sig and look for the one with EATC in the name.
